Hi, i just recently got the FE11S. It is my first Sony laptop, and I like it very much. It's fast, quiet, good preformance, huge harddisk (for a loptop). I compared it with the previous FS version.
First thing I ran into was the Bluetooth wich was not switched on. If you are a new user you will have a hard time finding the "switch" wich is not a switch...after 1 hour I finally found it in vaio controll center...very annoying....:smileycry:
3 things I don't like about it, I might find more the coming days:
1. The bad position of the touchpad and button (way to low).
2. The SD card reader you can put it into your slot wich to my disappiontment is sticking out a bit...
3. The Screen can't be opened as far like the FS version
My question:
In my mousepad settings I would like to adjust the sensebility of the touchpad. To my dissappiontment I can't find the option. Is there a way I can adjust it....?
The new hard disk recovery system Sony uses does NOT support Norton Ghost
Use TrueImage
thanks,
i think i will remove norton Ghost.
it's taking more time now to start up the FE11-S, so removing programmes i dont use is necessary.
also I think Quick Time is pointless to have in addition to Sony Centre, Windows Media Player.
Also i installed iTunes, as I have an Shuffle.
Use TrueImage
