Vaio vgn-fe11s "PCI Device" problem during Winxp pro installation
Werve
As it was posted by another fellow before me the uknown "PCI Device" is actually the Conexant HDAUDIO internal modem.
I experience excactly the same problem: the modem driver won't install under winxp pro even when i use the driver provided by sony.
Does anyone know where this KB83522 patch can be found? It seems that this is the solution to the problem.
Thanks
2 REPLIES 2
ocatarineta
It is in the origianl package of fixes you can find in the "system" backup DVD.
Werve
Thank you!
A little after I posted this thread i found this patch inside Realtek's High Definition Audio Drivers but i'll definately go for the original. Thanks again...
