I just upgraded to lollipop and now im missing the lock screen effect with the particles animation following you finger when swiping.
Also noticed that the facelock option has dissapered from lock/unlock options.
Anyone got any solutions to this?
That's strange, it's works for me but only if i use our themes. If i select a picture under Settings -> Personalisation -> Wallpaper -> Lock screen (or Home and lockscreen) i don't get the particle effect. If i then select the theme called "Xperia" i get the particle effect again. I've forwarded that internally to see if that's how it's supposed to work.
What happens if you try this in safe mode?
Could you try if it works in safe mode? Hold the on/off button and then tap and hold the shutdown option to restart in safe mode.
I got some more information about it not working with other themes and it's not an issue with the software. To see that effect you need to use a default theme and you can't select another picture as wallpaper.
The effect it's available on the Z3 tablet compact but it is not on the Z3.
@Rickard any info on this?
I've tested it on both Z3 and Z3 Compact and on several units but i can't find any issue with the effect. As long as i use the default theme i see the effect.
Do you also see this issue on Z3 when using the default theme?
