Sony WH-1000XM3 general question
profile.country.AU.title
skk02911
I was at school today with my new Wh-1000xm3, everything was good until there was an incident which casued a fairly a notable amount of water to splash on to my head and my back. The thing is that some of the water got on to the surface of the Xm3 (NOTE that it was not soaking wet) , luckily no water went inside the speakers of the headphone because I was wearing them. I noticed that there was a droplet of water inside one of the holes on the surface (maybe the mic idk) beneath the headband. I wiped everything off and turned the headset off would it be okay? And is the XM3 water resistant to some degree or is it not?
IamNic
Hello @skk02911,
since the headphones are sweat-resistant, I would say they are ok.
To be sure I would dry them off by letting them sit near a radiator or gently drying them with a hair dryer (from a distance).
- Nic
IamNic
Hello @skk02911,
- Nic
