MDR 1000X headphones bracket has broken
profile.country.RO.title
andreioros
I purchased my SONY MDR-1000XB headphones in January 2017, from www.altex.ro
I used them exclusively at work a (noisy) office environment - I am very happy with both the sound quality and NC.
However, the build quality is disappointing, especially considering the fact that the headphones costed 380 euro: this week I've noticed that the plastic of the bracket is cracked.
IamNic
Hello @andreioros,
if your headphones are still within warranty as you say, they should be repaired without additional cost.
- Nic
19 REPLIES 19
IamNic
Hello @andreioros,
would you mind sending me your serial number via PM so I can check back with support if your pair of headphones is elligable for a repair?
- Nic
andreioros
sent via PM
thanks
IamNic
Hi @andreioros,
I received the message. I will get back to you as soon as I get a reply from support.
- Nic
Broka1979
I have the same issue with my MDR 1000X, I'll be sending you a pm also regarding this issue.
andreioros
any updates?
IamNic
Hi @andreioros,
not yet, I would have messaged you otherwise. :slight_frown:
- Nic
andreioros
@IamNic still no answer from support ? it's been 2 weeks now..
IamNic
Hello @andreioros,
sorry I had a little back and forth with support, since accordin to support you are out of warranty and have to send it in for repair by yourself.
- Nic
andreioros
It can't be out of warranty: it is valid 2 years from the purchase date, which means until January 2019.. and there are 6 more months until then.
