Sorting Tracks To Album on Vaio
When I try and add new tracks to an exsisting album on my vaio it jumps into another album , although it shows on sonic stage that it is in the album I sent it to.
Any help or advice please/
3 REPLIES 3
krt951
Have a look at the album/tracks in sonic stage. Right click on track and select properties.Look at track info tab,then see if the "source" has the album title, if it is blank type in the same detail as the original tracks.
terrylong
One way you can do it is by selecting the album that the track is showing in, right click on the track and select move to new group. Depending on where the correct album is you can move the track (one album at a time) up or down until it resides in the right album.
Hope this helps
Thank you for your help. My problem has been sorted.
Many Thanks
