Sony Vaio Duo 11 digitizer pen issues
profile.country.en_GB.title
ioannis1971
Hi, I have a Duo 11 and a) my digitizer pen doesnt register at all any clicks of,the buttons and b) to use it I have to press it hard in order to write down or click something. A week ago it used to be more sensitive. Now I get tired by the pressure I put to write with the pen. I tried to reinstall the drivers through Assist but there are no pen and touch drivers anywhere - including the support site.
Any ideas?
Message was edited by: ioannis1971
stavrosd2006
hi there,
did you put in a new battery? may it was depleted fast if accidentally a button
was kept pressed for a long time.(lets say during storage)
do NOT press hard on screen,you will definetely damge it through time.
Do you have friend, or a Sony Center near you? i would suggest to try stylus
in another vaio to see if it is working on that one,and thus exclude
computer malfunction.
post your results.
Good luck.
3 REPLIES 3
stavrosd2006
hi there,
post your results.
Good luck.
ioannis1971
ok I feel like a complete idiot. Changing the battery was something that I didn't think of since I had hardly used the pen and the laptop is 5 months old.
Thanks for the tip! I changed the battery and is working fine now (although in the meantime I have ordered another pen in case the original one was malfunctioning).. Now I have 2!
Thanks Stavros.
John
JayKannan
Have you tried this driver from NTrig? http://www.n-trig.com/files/Win8_Driver_x64_v2.zip
I'm yet to try with photoshop, but it installed okay and doesn't conflict with the existing driver
