can i upgrade the cpu from xl202??
i want to change the faster cpu
Please HELP
Hello Mouniros!
I see also this power supply on the net and personnely I find it "too much". It provide much more power that I need on a HTPC configuration. So I will not buy it. And what I didn't like is that the power supply is going outside the case. So many cables that look not fine! What I'm looking for is a power supply with the same size to put inside the case and that provide 400W of power. So I can use the Galaxy 9600GT with it! But, for the moment I didn't find one...
So I think that I'm gonna take the 8500GT that works with original power supply.
A+
Gladiateur555
Good,
Have someone tested Core 2 Quad 6x00?
Thank you
Max
They have, it doesn't work 100%. The BIOS doesn't recognise the CPU and so you get a micro code error every time you boot. This means you have to press a key before it will continue booting. It will then boot into Windows but there is a question mark over the stability of the system...
