saabfast
3D TV Operation
Is there any way to check if the 3D transmitter is working?   I have a KDL-40HX803 TV with BDP-S570 3D Bluray player.   I have just got a BR-100 transmitter and BR250 glasses.   However, something does not seem to be working as 3D discs do not appear as a clear 3D picture (the screen looks the same without glasses).   The glasses turn on with a flashing LED as they should but there does not seem to be anyway to check the transmitter is working.  Any suggestions?
Anonymous
Not applicable
Hi there
From my understanding of your issue, I think it could be due to the HDMI cable - I would advise changing it due to the fact that the HDMI cable also has to support 3D.  Have a look on Amazon.  A couple of examples are:
http://www.amazon.co.uk/PRO-GOLD-RED-Version-18Gbps-Black-white/dp/B0031APPM4/
http://www.amazon.co.uk/AmazonBasics-High-Speed-Supports-Ethernet-Standard/dp/B003L1ZYYM/
4 REPLIES 4
Anonymous
Not applicable
Hi there
When you play a 3D movie from your Bluray player, do you get a message on your TV screen saying "3D Signal is Detected" or something like that ?
I have had a look at the specs, of your equipment, and all should be compatible with each other.  There is 1 item that may have been overlooked.  Its the HDMI cable.  You will need at least a HDMI 1.4 cable for 3D.  They are relatively cheap on Amazon.
saabfast
Thanks.   I have no idea of the HDMI cable spec (bought a few years ago with the Bluray player), but it has never given a problem and the picture with a 3D disc does not look normal.
I have not seen a â€˜3D signal’ message but on the home screen it does show the disc as 3D and 'Information' shows it as 3D.
Anonymous
Not applicable
Hi there
saabfast
Thanks, have just ordered a new cable to try.
