Sony Bravia KDL46W905A p&p input question
MarkMark
Hi, I have my xbox connected via hdmi, I want to try use my apple tv or bluray player as the 2nd picture in the p&p or picture in picture. It can't use two hdmi inputs for p&p.
It says in the manual "when the main picture source is an HDMI input, the sub picture source can be:
Digital Programme
Analogue Programme
Video Input.
Now video input is what I'm after but hdmi is out, excuse my ignorance but what constitutes a "video input" and since hdmi can't be used, is there a way to convert the hdmi out on my bluray or apple tv into a "video input"?
On the back it has a scart input with smartlink, scart without smartlink, component video and composite input.
Are these all video inputs and is it possible to change a hdmi out into one of these?
Thanks for your time.
Mark
Anonymous
Not applicable
Hi there
I have just tested my TV with this (KDL-42W807A 2013) and have the same.  I can use 1 HDMI port (ie my PS3) and either the TV's tuner, or the AV1/AV2.  These two are the SCART/Component inputs and I believe this is what "Video Input" is.
You can find HDMI to SCART converters on Amazon.  (eg HERE)
As well as HDMI to Component (eg HERE)
I believe it will work, but cannot guarrantee - due to the fact that I havent done it myself :slight_smile:
Anonymous
Not applicable
Hi there
