Xperia E5 in charge
Byron69
Xperia E5 in charge
Mi xpiria no carga y cuando lo hace es por corto tiempo que puede ser ayuda
My xperia does not load and when it does is for short time it can be help
GT
Jonas
Master
Hi @Byron69, welcome to our forum and I'm sorry to hear about this. Slightly_frowning_Face
Your question has been translated to English, since this is an English only forum. Please post any further replies or feedback in English.
Do I understand correctly that when you are charging your device, it only charges for a short amount of time and then it stops charging? Have you tried to charge the device when it is powered off as well and you have experienced the same behaviour?
Make sure that you are using the USB cable that was included together with the device and/or the wall mounted charger.
If one of your friends, family members or colleagues also have an Xperia device, you can ask them if you can borrow their cable/charger and see if you still experience the same behaviour.
Should there be no change after trying the above, try rebooting your phone in safe mode so we can make sure that no downloaded application(s) are the cause of this.
Let me know how it goes!
