I forgot the unock pattern of my Xperia E5. May I ask you how can I unlock my phone again?
Don't despair, Uliwooly is here to save the day, take a look at this.
/t5/FAQ/How-to-unlock-a-phone-w-o-reseting-reformating-the-phone/td-p/927295
Thanks @uliwooly for the help, but the information reported in your post doesn't help since I do not have the 6 digits code to use the block option.
The lock system I'm using on the phone is the pattern. In the link you posted there are solutions to pin and password issues, but not for the pattern.
In the unlock method you reported in your post you're referring to a 4 digits code, but it doesn't appear anywhere.
Finally i found my way out thanks to the info in your previous post after I played a bit.
I would thank you for your help, have a nice day!
I forgot the pattern of my smartphone,a Sony Xperia E5, and "my Xperia" isn´t active. Has somebody a idea to unlock it? Also the tool from google don´t helps
Thank you
