Unlock Pattern forgot. How can I unlock my phone?
Edb1
I forgot the unock pattern of my Xperia E5. May I ask you how can I unlock my phone again?
Uliwooly
7 REPLIES 7
Uliwooly
@Edb1
Don't despair, Uliwooly is here to save the day, take a look at this.
/t5/FAQ/How-to-unlock-a-phone-w-o-reseting-reformating-the-phone/td-p/927295
Edb1
Thanks @uliwooly for the help, but the information reported in your post doesn't help since I do not have the 6 digits code to use the block option.
Uliwooly
@Edb1
Then what are you referring to?
Edb1
The lock system I'm using on the phone is the pattern. In the link you posted there are solutions to pin and password issues, but not for the pattern.
In the unlock method you reported in your post you're referring to a 4 digits code, but it doesn't appear anywhere.
Edb1
Finally i found my way out thanks to the info in your previous post after I played a bit.
I would thank you for your help, have a nice day!
Uliwooly
@Edb1
Great news
MAL9
I forgot the pattern of my smartphone,a Sony Xperia E5, and "my Xperia" isn´t active. Has somebody a idea to unlock it? Also the tool from google don´t helps
Thank you
