- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
The GPS test can fail if you for example are located in a building where objects are surrounding you. Have you tried the GPS test outside? You can also take a look at the following FAQ-topic for some tips:
/t5/FAQ/GPS/m-p/351902
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have researched this numerous times and tried everything suggested that I could find.....
My GPS on my Z3 Compact used to work. Now the diagnostic gps test just says failed all the time. My GPS will place me sometimes if I am still but it losses it as soon as I move therefore making it useless.
I use my phone a lot for satnav and tracking running so for it now not to work is really annoying.
I've read people saying it's a software problem, my phone has since updated yet it's still not fixed.
When can we expect this problem to be resolved?
I've put my sim card in my old xperia Z and the gps is fine so it's definitely the phone.
Any advise welcome!
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I am floored by the official SONY forum response to this. My Z3 Compact is exhibiting the same problems as stated in all the GPS issue threads on this site. While looking to see if others have received a solution or fix to this problem I stumble across your incredibly banal and unhelpful post that is so deflective in nature that I had to respond. Do you think we are idiots? We're having GPS problems with our phone, we're calling support lines, posting on these forums, and sharing information with eachother. If somebody has done enough detective work into this issue that they're checking the GPS diagnostics in the troubleshooting backdoor of this device do you REALLY think they would be so stupid to be doing it indoors? This is infuriating!
SONY WAKE UP! FIND A SOLUTION TO THIS PROBLEM! We have spent incredible amounts of money on this overpriced device and expect support! This is NOT a new issue!
Sold my PS4 because it was junk, and now about to throw this device out because it is junk as well. With support like this what do you expect?! What happened to this company? When did you become the low end of the retail electronics market?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@Jodi, Have you also tried a software repair via PC Companion? This will reinstall the latest software available for your phone. When the software repair is done, I suggest that you wait to install applications/restore backups to see if same behaviour appear.
@GregRell, I'm sorry to hear that you feel that way. The FAQ topic (regarding GPS) that I've mentioned in my previous post, covers the most parts regarding GPS. If you have tried those steps and also a software repair via PC Companion, I suggest that you have your phone examined by a technician at an authorized service center. You can contact your Local support for information about nearest service center and/or how to proceed with this in the best possible way.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
After FIX from SONY my z3 compact GPS work fine but reset the entire phone for a stupid software bug is not a good solution
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Again gps is offline
Anad now , Reset ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hello PLS are there any plans that you will fix this problem with GPS with some update? For example like in M2 model?
Searching SONY for the problem? Because I did everything acoording to SONY advices but GPS still not functional.
Thank You
