Since I made the last update yesterday 10.1.1.A.1.253 I have in my lockscreen, a home button and back button?? Does anyne know how to remove them??And why do I have them on the lockscreen???Sry about the bad picture but I had to take it with the PC camera as the sony doesn´t let me do the screen shot. When I make a screenshot on the lockscreen the both buttons dissappears immediately.
Does anyone has the same problem?
So like the comment before if you have this problem the solution is to remove SmartKey. Uninstall it and you won't have home and back button on lockscreen. Thank you!
which app(s) do you have open? unlock the screen and check if you have anything open or is it just the homescreen?
I have this problem for one month plus. U can get rid the home n back button from home screen by doing a repair using pc companIon or factory reset under setting. But these method are not long term solution. I still have this same problem few days after repair or reset.
I've seen it on my lockscreen, that's when I press and hold the power button, how come repairing your phone its not an option? why is it that you can't take screenshots?
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Don't forget to mark the Correct Answers & Helpful Answers
Check that whether you use smart key app in your phone..if yes..remove it..
u can solve the problem..
i had same problem and i fixed it like this..
When trying to take screenshot, the home and back buttons will go down and there is why cant take screenshot.
I have smart key app. But wasnt this app comes along with the phone? Confirm remove this app will work? Ok i will try and many thanks for providing this information.
Thanks. It worked! :smileyhappy::smileyhappy::smileyhappy:
