Sony z3 compact xperia back and home button not working
User105
I am using z3 for almost a year and dint have any issues. Since last two updates i am facing two problems.
1. The drop down notification menu does not displays properly when slided over from top to bottom
2. Back and home button works once in a blue moon. Previously they were working great. Now i will have to try for more than 25 times to make that happen or restart the device.
Please let me know if this is a software issue caused by the latest software release or is there a way to bring back the old version of software. Eventually i need a working software and not this piece of ugly software quality.
Please respond when this issue will be resolved.
467 REPLIES 467
xavinux
Enthusiast
Hi @User105
Please, first run a backup of the device information as explained here. Then perform a system repair using PC Companion orBridge for MAC. The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 80% battery. Switch off your phone and unplug from Pc (Hold volume up and power for around 10 seconds) Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the on screen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process. If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP. Keep us updated please, I´m at disposal for any question.
Uliwooly
@User105
Do you experience the same while on safe mode
User105
@uliwooly: safe mode as well has the same problem. I apply also ran into touch screen diagnostics. Few of the time it works and most of the time it fails. Am sure it's some thing to do with the latest update. Any other z3 compact users facing this issue.?
@ xavinux: will try your suggestion and update.
xavinux
Enthusiast
Hi @User105
Ok, please keep us updated, I'm at disposal for any question.
hue899
Hi @xavinux !
Im facing similar issue as @User105.
Had been using Z3 comapact for a year.
After the recent update, the Back button and Drop-down Noification do not respond.
Had tried ran a backup, followed by PC Companion -Support Zone (by clicking on blue link: Repar phone/tablet).
But issue does not resolve.
Had also tried 'touch screen diagnostics' using Xperia Diagnostics app, nothing wrong with the touch screen.
But Back button and Drop-down Noification are still not working.
Appreciate you could advice!
Thanks in advance! Upside-down_Face
User105
@Xavinux
Your solution don't work either. Am sure it's because of the latest update. I need to restart my phone every time... And together without the drop down notification, I am using my phone to attend the call. Please suggest a solution as soon as possible. Or try to rollback the latest two updates. Or pls share the link for users who wanna do that. Thanks.
User105
And it's not a hardware problem. Touch at that location of back button works fine on the lock screen. Hope there is a solution and we can expect soon.
xavinux
Enthusiast
Hi @User105 @hue899
Please, can you tell me which version of Android OS and the software update number your have installed on your device?
User105
Android version: 5.1.1
Build number: 23.4.A.1.232
Additional information:
Kernel version:
3.4.0-perf-g5c87ba0-02008-gbe52486
Baseband version:
8974-AAAAANAZQ-29481-1-53
