Screen display issues
GELÖST
Cobby1
Besucher
Have a permanent line across top of display like a row of unused pixels. Also often, but not all the time, have a 'ghost' image of remains on screen when scrolling to a new part of the content, stays there. Finally, sometimes the display simply has noise like fuzzy bands running down the screen. Anyone else have this. Is there a fix or is my device simply broken?
Tags (1)
1 AKZEPTIERTE LÖSUNG
Akzeptierte Lösungen
Cobby1
Besucher
Turns out to be a faulty screen. Amazon replaced without any quibbles. Thanks for responding.
3 ANTWORTEN 3
profile.country.PH.title
MarlonUk1
this seems to be a hardware problem,. but lets make sure it isn;t caused by sofware
try to run Xperia Diagnostics. settings>about phone
boot to safe mode
try to perform software repair using Xperia Companion
if the problems exists still. you have to send your device to your local service center Local support
Andrej123
Besucher
I have ghosting on my new Xzs as well. Changed it for a new one, that has the same problem. So maybe it is very comon, but not everybody has noticed it yet...
Cobby1
Besucher
