- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Post Software update setup wifi connection
Hello all,
My F8132 had a broken screen so I got it replaced and my power button caused my screen to freeze.
So I decided to reload Android via Xperia Companion, software repair worked as advertised.
Went setup after software install, intital steps all work and then I have to connect to WIFI. It wont connect.
I try to use mobile data, does not work as well.
I have read every topic on the forum here and tried them all over 2 days. Change IP, reboot router, all suggested fixes and no joy.
I even tried to use the boot unlocker and Emma but I cant use the phone dialer becuase of incomplete setup (emergency dialer does not work for this).
What am I missing? Am I stuck?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Check if your battery is charged > 80% and do the software repair with Xperia Companion again.
Finding out what went wrong is of a job and a new setup probably resolves the problem.
Good luck!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
No difference, same result. Cant connect to internet, connecting to wifi is not problem. Wifi and data, neither work.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Then skip automatic APN setup.
Go to your providers website and find the proper APN settings.
Goto settings-network & internet-mobile network-APN or access point names
Create a new APN, save and use that one.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I probably was not clear enough:
When in setup after a software repair,
I am asked to:
Choose language
confrim sim card
Connect to wifi
Once connected, phone goes online to connect to Google for some part of the OS.
This is where it fails, I can connect to wifi but it says "No internet connection" .
All solutions related to the working with a functoning OS "system" via menu are not possible.
The OS setup cant be completed, therefore I cannot continue.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
My earlier hint was about setting up mobile network.
Is your WiFi network functioning as it should?
Have you tried another WiFi network?
