Partilhe a sua experiência!
I have just bought these headphones and the audio quality on calls is terrible. People I speak with on the phone report that the microphone is dampening my voice, making it sound echo-ey, whilst at the same time picking up ambient noise. Indeed, most report that the ambient noise is clearer than my voice! I'm not tryign to make calls in a particularly noisy environment - just a regular office.
Any ideas?
@paplorinc wrote:I have the same problem, the mic sounds like this guys's: https://youtu.be/cZwr8D-qYHk?t=160
Should I return the unit?
Yes @paplorinc. Have them replaced.
A quick update:
I raised a ticket with Sony support. They made me go through a rudimentary diagnostic procedure (factory reset, etc.) which made no difference. They then said they would pass it on to a second line support team and I nevertheless heard anything back.
In the meantime I returned the headset, following @Octado’s advice. The new headphones do a better job of rejecting ambient noise, however callers report my voice, although now clear, is still muffled and they are having to strain to hear it. I tried to take it back a second time and the ship said it was probably not a hardware fault but my expectations.
From comparisons with colleagues who have the Bose QC35, the Sony mic definitely dampens the voice - however the Sony mic noise rejection is much, much, better.
i’m still not happy as I make a lot of calls and don’t want to carry two headsets. What advice can others offer now?
Same issue
I can t call people.They don't understand what I say and hear their own voice. I always need to cut the bluetooth and use the phone. It's a shame because they are designed to be used with smart phones. I m getting nervous.
I use a Samsung S-5 and updated the headset to V2 firmware
Phonecalls are terrible!
NC goes off and ambient sound kicks in.
It even turns the ambient sound louder than what you hear whitout the headphones.
NC/Ambient button does nothing...
I had the same problem. The first day, i did not have the problem. The problem actually started after I installed the headphones app and changed the NC/AMBIENT button to control Google Assistant.
Just now i tried to change the function back to control the ambient sound. Then, i made a phone call and during the phone call i were able to change from "ambient sound" to "noise cancelling" and i litterally hear no sound from the environment I'm currently in.
So for me, my problem is now solved.
Hi I have the same problem, people are complaining I sound muffled and is not as good as my Bose headphones. Sony do you have a fix? Otherwise a great product for noise cancellation but poor on calls.
I too have this problem and it's very annoying.
I called Sony tech support but they said I could only send to a repair centre to have them test and report.
I mentioned that this appears to be a common issue and replacement sets appeared to be better but they said they could not offer replacements only a repair check.
The headphones were purchased from Richer sounds - however the receipt says 'due to hygiene reasons we are unable to offer refunds or exchanges on headphones!'
