- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
February 2021
February 2021
Hi Folks,
Just wondering if anyone has got an A105 connected to a headphone amp or amp/dac combi successfully through the USB C connection . Tried a Zen Dac but no audio
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
February 2021
February 2021
I believe it should work just fine with 3.5mm/RCA.
AFAIK different cables/connections only impact the number of channels (3.5mm being limited to Stereo 2.0 for example) but not the quality, unless you go wireless, then it depends on the method, codec, etc.
- JD
3 REPLIES 3
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
February 2021
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
February 2021
February 2021
So it would be 3.5mm to 3.5mm or 3.5mm to rca then ?
Newb question would that still output hi res like dsd128 if it’s connected up to a headphone amp ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
February 2021
