nwz-b162 screen problem
thes1nner
My nwz-b162 walkman's screen is not working. Everything else is okay. When i open it or plug it for charging, just lights are showing up. No letters. I tried resetting it but it didn't work. Also, the screen turned back to normal for a minute but after that no letters again, just lights. How can i fix it?
4 REPLIES 4
Pascale_F
Moderator
Hi thes1nner,
Welcome to the community.
First, see if you can make sure your NWZ-B162 has been updated to the latest firmware to see if this helps. You can follow these instructions to do so. Let us know how you get on.
Thanks,
Pascale_F
thes1nner
Hi, thank you. I installed Media Go and checked updates.Now it looks like this. The screen turned back to normal for 4-5 seconds earlier while i was trying to finish the battery. I finished it and plugged back but the screen is again blank, just lights are on. 123.JPG
Pascale_F
Moderator
Hi thes1nner,
Okay, try performing a reset on your Walkman player. To do this, have a look at points 6-8 on this page. If this doesn't work, it's best to contact Sony Support here to see what they can suggest.
Thanks,
Pascale_F
thes1nner
Reset is not helping. I contacted Sony support. Maybe I can format the walkman using settings but I need another walkman to complete the steps successfully. I searched for videos or images for the menu but I couldn't find anything helps.
