WHERE CAN I DOWNLOAD THIS SOFTWARE PLEASE,THANKS
Just a tip with Acronis. Make sure you make bootable CD's say 12 for 14 gigs of data before you start making the image. If you want to make a DVD set image you will need a special UDF iso set of DVD conversion drivers from Nero and even then it may be a problem getting it to work.with DVD's. External hard drive is the best way but of course you will not be able to format the C drive if you have a malicious virus but External HD is the quickest problem free way. Just plug in and restore the system.
I use the hard disk option
thamks for your replies.i have got an external hard drive from my previous laptop with the xp os on it with c&d drive that i can connect to my new laptop how do i then transfer or copy my settings to it? would i need to remove the whole content of c drive?please help
