does the vgn-20ef have 802.11n built in cos it doesnt say in manaul and different website say different things some say 802.11n and some say 802.11n (draft) as i want to upgrade to a n router so has it or would i need to buy a wireless n adapter cheers
801.11n was not actually certified as a universal standard until October 2009 - which is after your VGN-NW20EF was first released.
Between 2006 and October 2009 there were a few different Draft N standards. The final version is backward compatible with the previous draft standards.
As your Vaio was released just before final certification, I have no doubt that your Vaio will be compatible with the new certified 802.11n standard and should connect OK to a new a/b/g/n router.
Hi mesimps71 and welcome.
The Specifications on the Sony website say: -
Wireless LAN Max. Date Rate (Mbps) | 300 (RX)/ 150 (TX) |
Wireless LAN Range (m) | max. 100 |
Wireless LAN Type | 802.11a/b/g Draft n |
http://www.sony.co.uk/product/vn-nw-series/vgn-nw20ef-p
so is it a 802.11 n or not?
what is draft n? that doesn't really answer my question
