A417M USB USB2 ???
j2d2
A417M USB USB2 ???
Hi
The specs says my A417M has 3 USB ports and it's USB2. However when I plug in a USB2 device into one port the A417M freezes until I unplug it (the port on the left). Then when I plug it into either of the two ports at the back a XP pop-up says it's a USB2 device and it could operate faster if it were plugged into a USB2 port (and click here to see which one) - so I click and it lists a USB2 port - but which one is it? All three are supposed to be USB2. When I right-click My Computer and look into Hardware tab and devices etc there seems to be 3 USB hubs defined and one USB2 - that's four - but there are not four ports! What's that all about???? I need this FusionHDTV DVB-T on a USB2 because digital video would be too slow on USB. Are these ports USB 2.0 BUS powered??? Do I need to buy a powered USB2 hub and plug it in??? But I'm not convinced that any of the three ports are USB2 yet ... Any ideas??? Thanks.
4 REPLIES 4
profile.country.en_GB.title
kee-lo_
From what it says they're all USB2
No idea why they're not playing ball
William
According to Specs your 3 USB ports are are USB2. Try going into the Bios at startup and loading default.
j2d2
After several power on/off with FusionHDTV plugged-in and reinstall of FusionHDTV drivers it all seem to come good .... and btw the HDTV product seems to be very good. I bought the A417M in the UK but I'm in Aus where I bought the FusionHDTV.
I still don't understand why (although I am an IT professional!) - and I'm deciding whether to download and install latest version from the DVICO web site (they make the usb tv).
Thanks anyway.
kee-lo_
Strange how sometimes things can just work
