Sony KDL26EX320bu Television
profile.country.en_GB.title
deralexa6
I am looking for help on best picture settings for my sony KDL26EX320bu tv. I have tried various combinations in the picture menu to increase the brightness but the picture still appears to be on the dull side.
Message was edited by: deralexa6
KDL-CX520
I own a different model but this may be help you (i was having the same issue as yours)
by using the remote reset you TV to factory setting.
At the start up the TV will ask you to choose between SHOP mode or HOME mode....you choose SHOP mode which will give you much more conrtast and deeper colors than HOME mode.
Another point you may consider, that you switch OFF the light sensor option in the menu.
3 REPLIES 3
KDL-CX520
deralexa6
Tried your suggestions tv picture is now normal ie its a lot brighter. Thanks very much
KDL-CX520
You are welcome ,  it was nice to share you the information
