hanging up problm
jagroop
hanging up problm
We bought tgis 2days before n from very first day it started hanging pls help
Tags (1)
blackmagic
Can be any computer. Sony PC Companion application on a computer, install
22 REPLIES 22
blackmagic
What exactly is your problem?
jagroop
Pls guys help me out
M vry disappointed n nervous
blackmagic
If you specify the problem clearly we will try to help
jagroop
My problm is whenever i use it and after a while whenever i want to reuse it its swipe n unlock doesnot work even if i try to poweroff it doesnot recognize my touch
jagroop
Its hangs does not work till i take out its battery n reinstall n power on it then also after a while it start the same problm
blackmagic
Have you tried to repair the software via computer
jagroop
No because i do not have pc
jagroop
Should i hv to do so
jagroop
Pls guys help me out m dying because i switched from samsung to sony
