- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I have a google home mini in my room.
I was looking to able to use this soundbar (Bluetooth and non WiFi I believe) to be used as a speaker from my google home and also when I want to play music from my phone via Bluetooth. My question is could the soundbar have both my phone and google as connections and jump to whichever one is playing music.
My Bluetooth is always turned on on my phone, so is the soundbar smart enough to go to the google if my phone is not playing music?
thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
In the image above you only have your GoogleHome mini device and the Android TV, after pairing you should also have the Soundbar and you should be able to select it by pressing on it (that section is used to choose the device that will play music and audio).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Actually it should already be okay because Bluetooth 4.2 Speaker is selected and then you should hear the music from the Soundbar...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes that’s what I thought, I hear the music via speaker 4.2, just not the audio (as in google talking). I’m not sure how to get the audio to the speaker
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Maybe this is the difference to soundbars with google?
or what is the difference you know of from soundbars to soundbars that work with google?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Ok so I was thinking that may be it. So a soundbar that works with google. Actually has a google built in?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
In UK? This is the only one (on Sony site) who work with Google Assistant:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Ok, on the link page I used a filter to search for products that have the Google Assistant but there are others, you have to look for the models that "declare": Work with Google Assistant ...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
The HT-ZF9 is the only soundbar which comes with Google assistant.
