remote control affecting my tv
profile.country.sk_SK.title
patrik.kontul
Hi all,
I have HX-980 hdd rec. and its work just fine, but when i use rem control it always change input on my tv (ovp 2545 ctv). Looks like tv is receiving commands from hdd remote control..
Any help, ideas, please share
many thanks
Tags (3)
6 REPLIES 6
rooobb
It's not clear which is your TV and how they are connected (via HDMI?). In any case, if they interfere your recorder machine has 3 different command mode (default is DVD3) that you can choose
patrik.kontul
hey
TV is old model OVP 2545 ctv.
Tv is connected via simple scart
So you saying that i can change mode how HX980 can "talk" with remote contrl so later it wouldnt interfere with tv..
That would be the solution i guess, how can i change that mode?
Thanks for help mate
P
rooobb
Be aware that I've the documentation in Italian and my model is the 870, but they should work in the very same way.
You should set the same "Command mode" in both the recorder and the remote.
In the recorder you should find the setting in System menu-->Initial setting-->Options-->Command mode
Choose DVD1 or DVD2 (as I sayd DVD3 is the default)
Then you should set the same on the remote:
press ENTER and, while pressing it, push #1 (for DVD1) or #2 (for DVD2) and keep them pressed for more the 3 seconds. (if something fails you can always reset everything...)
Hope it solve your problems :slight_smile:
patrik.kontul
Hi there,
Thanks for help, i just tried and unfortunately it didnt help.
I tried all options (1,2,3)
Looks like i should buy some new tv..:)
rooobb
Have you tried (if available) to change the scart input in your television (Av1 to Av2 or viceversa)? Maybe you are using a smartlink connection and it gives you some side effects
patrik.kontul
Maybe, actually i even dont know what is smartlink..
but i will try to change input in tv
thanks for try
..happy
