I have just purchased a PS-HX500 turntable to link to my Sony Bravia 4KTV and Skye Soundbox. I cannot get any response through the TV which according to the instruction manual is quite straightforward with the phono jacks.
I can get the Hi-Res recording through my computer then transferred by Bluetooth to the Soundbox. But this is a complicated way when I just want to hear my vinyl collection.
Can anyone suggest why my tv will not connect direct to my turntable? I am not an expert and am now totally perplexed since I only bought the Sony Bravia 19 months ago along with a Sony 4K player. Any advice/help would be appreciated.
Sony Drew
Hello @davidduncan1941,
trough which type of cable did you connect the turntable to your TV - I would assume a Chinch (white/red) to 3.5mm TRS connector. Is that right? Or does your TV have a dedicated composite video (yellow) + chinch (white/red) input?
In the former case - you need to use a TRRS to Composite Video (yellow) + Chinch (white/red) cable. Also important here is, that these cables are not standardized in terms of the assignment of the contacts, meaning the cable-end colors can be mixed up in function.
For the latter - it should work right away if you select the right input for your TV.
- Nic
Many thanks. Will try what you say. The cable supplied was only red/ white to red/white but the tv has red/white/yellow. Thanks, David.
