Hi I'm having a problem with the microphone of the phone, it stops working and always I have to restart the phone, but then after a while the microphone is muted again. What do you recommend me to do?
Unable the Google's feed, or the whole app and try. It worked for me.
Translation via Google Translate:
How did you solve it, friend and the same thing happens to me?
Como lo solucionaste amigo ya k me pasa lo mismo
El micrófono 🎤 de mi Sony no funciona. En llamadas yo escucho y a mi no me oyen, en pruebas de grabación de audio tampoco. Solo funciona si reinicio el Equipo. Puedo hablar o enviar audios no por mas de 10minutos Y vuelve a fallar. En llamadas la única forma de que me escuchen es activando Altavoz (cosa rara) o usando auriculares que puedo hacer? Será el software? O debo enviarlo a servicio técnico?
The microphone 🎤 of my Sony does not work. In calls I listen and I do not hear, in audio recording tests either. It only works if I restart the Device. I can talk or send audios for no more than 10 minutes and it fails again. In calls the only way to listen to me is by activating Speaker (rare thing) or using headphones that I can do? Will it be the software? Or should I send it to technical service?
GT
Hi @zalo87,
As this is a international community I have translated your previous post in to English. Please keep all future posts in English so that other users may understand you.
I'm sorry to hear this.
I recommend that you reboot your device to safe mode to see if this behavior is caused by one of your downloaded apps as these will be temporarily disabled in this mode.
If you are still experiencing the same behavior, I would recommend that you perform a software repair using Xperia Companion.
Keep me posted how it goes.
cara se vc resolveu o problema do seu microfone me ajuda por favor ,estou com o mesmo problema
Dude, if you solved the problem with your microphone, help me please, I have the same problem.
GT
I had the same problem. Sent mine off to repair and got it back but it still doesn't work properly. It works intermittently which is very annoying as it obviously isn't anything to do with settings if it can work at some points but not others!? Sending it off again. Aux doesn't always work either, again this is random.
