WLAN disfunction: impossible to Start Wlan
Hi @Anton7, sorry to hear about this.
When you try to enable Wi-Fi in Settings > Wi-Fi, by dragging the slider to the right, is the slider not moving or can the phone not find any Wi-Fi networks when it has been enabled? Is there any change if you try and enable Wi-Fi from the quick settings in your phone? You can access the quick settings if you drag down the status bar in your phone.
If you can't enable Wi-Fi in Settings or in the quick settings, I would recommend that you reboot your phone in safe mode so we can see if a third party application is the cause of this.
Should you still not be able to activate Wi-Fi in safe mode, try performing a software repair using Xperia Companion. This will delete all data stored on the internal storage, so creating a backup using Xperia Companion is advised before you start with the repair.
Let me know how it went!
Hi Jonas
Yes, thank you, has worked. Wlan runs again normal.
Regards,
Anton
Hi again and I'm very happy to hear that it's working now again!
Should there be anything thing else you are wondering about, feel free to make a new post on our forum and me and my colleagues will do our best to assist you!
Have a great day!
good day, sorry, I tried to repair that same device with Xperia Companion and does not recognize the device after the restart of it, so it does not proceed to the repair process, what can I do in that case?
Hi @Manu-G-G, welcome to our forum!
I'm afraid that the Xperia E has not reached it's end of support and you are no longer able to perform a software repair, as the software is no longer available.
you do not know any way to repair it? With ISO file or another?😓
@Manu-G-G, You can take a look at the developer part of our Support forum and they may be able to assist you with flashing with the device, but that is not something that I will be able to assist you with.
