Do you have the possibility to try with different networks? It would be interesting to see if same behaviour appear at another network. I also suggest that you make sure that your router has the latest firmware to see if this can help.
Just to clarify, did changing your IP to static fix the problem?
One last thing I can suggest is that you make a full reset of your device. And when you configure your unit again and adds your Google-account, make sure that "Back up your device's apps, app data, settings and Wi-Fi passwords" is not marked to see if this can help.
I also have the same problem as everyone here . I tried everything but the ONLY solution for now it's just restarting the phone and wifi works again , It's really annoying because I have to do the same thing at least 2 or 3 times at day . But due to the phone boots quick , it's not a big deal to me at all .
The only problem that I'm facing now it's something that I don't know if it's an ilusion or it's real lol . I remember that the first days that I bought this phone , All youtube and other app videos play in 480p . But yesterday I saw my phone playing videos in 360p , I tried to change the conf in the youtube app but it only appears , 360p like the highest resolution ,
It's my phone , or everyone has the same problem ? .
