Using phonepad as default keyboard on E5
Trevtherev5
I've recently upgraded from e4 to e5 but can't work out how to change the qwerty keyboard to phonepad for messaging purposes - I did this with the e4 no problem! Can anyone help me please?
Jonas
Master
Hi @Trevtherev5, welcome to our forum!
The Swiftkey keyboard that is used in Xperia E5 does not feature this kind of layout (T9/Phonepad).
I would suggest that you search for "T9 keyboard/Phonepad keyboard" in the Google Play store and you should be able to find a keyboard that does have the layout that you are looking for.
After downloading a new keyboard you may have to enable it before you can choose it as your current keyboard. This can be done in Settings > Language & input > Current keyboard > More keyboards.
Let me know if that helps!
5 REPLIES 5
Jonas
Master
Trevtherev5
Hi Jonas, thanks for the tip, will check it out and reply back in due course 👍
Jonas
Master
You're welcome! Slightly_smiling_Face
Good luck with finding an application that suits you better!
Trevtherev5
Thanks Jonas, your advice worked at treat!
Jonas
Master
Hi again!
I'm happy to hear that you were able a keyboard that have this feature.
Let me know if there is anything else I may assist you with and have a great weekend! Slightly_smiling_Face
