Translation via Google Translate:
Hello, my phone goes off without warning and I have to turn it on several times a day, how can I solve this problem?
Hola, mi teléfono se apaga sin previo aviso y tengo que encenderlo varias veces al día, como puedo solucionar este problema?
I used Google Translate to find the meaning of your message. Kindly post your future questions/feedbacks in English so we can assist you, this is an English based forum.
Did you drop your phone or expose it to water recently?
If not, start troubleshooting by restarting your phone into safe mode, this will disable all installed 3rd party apps. If the problem is resolved then one of your installed apps is causing this issue and you have to figure out which one. Start by uninstalling those apps you installed recently.
