- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Earbuds from Xperia Arc not working on Xperia E4
Hi everyone,
I have earbuds from xperia arc, with which I'm satisfied regarding the sound reproduction on laptop or desktop. However, when I use these earbuds on E4 I get a message: "Headset not supported...", and I have to keep mic button pressed in order to have full quality sound.
I do have the earbuds that came with E4 and they work fine. Both of the earbuds (E4 and Arc) have three plastic stripes on them, so I guess the connection is the same.
So, the question is, is it possible to use headphones from Arc on E4?
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi, can you count the number of segments on the earphone plug? Or the number of bandshttps://cn.hama.com/bilder/00080/det/00080857det2.jpg
Dont mind me, I'm having a bad day.
you have the correct 4 pole connector on both they should work. Something weird is happening.. Gimme a sec to investigate
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Neo,
both of the plugs have the same number of segments and bands, as on this pic:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
God I'm even slow to reply and edit
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Check the height and see if the plug either sits higher or lower than the other jack when plugged in
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Actually, there's a pinout change, your Mic and Ground are reversed on the older phone
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It's the wiring inside. It's reversed. Which means off is on for microphone.
When you press the mic button, it sort of completes the circuit and you left and right finally get to have a proper reference (ground) signal
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
OK, so I can't use them on E4, what a bummer...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Some of electrical tape solved the issue.
