how do I restore factory settings on a WX100 camera
profile.country.en_GB.title
DeniseatLB
How do I get rid of 'Watercolour effect' when I don't want any effects - just a 'normal' photo please?
Will be so grateful for your help
Denise
Message was edited by: DeniseRead
blaireau_photo
Hello DeniseRead - Welcome to the Sony Forums :slight_smile:
Whilst trying to take a picture, if you press the MENU button and then PICTURE EFFECT, you will be able to select and deselect the various picture options including the Watercolour Effect. These are described in detail in the online Cyber Shot User Guide which can be found here:
http://esupport.sony.com/docs/dvimag/DSCWX100_WX150_guide/en/contents/02/04/06/06.html#l2_picture ef...
If you still cannot turn off the Watercolour Effect, you can also reset the camera to the factory settings by going to the MENU and choosing:
SETTINGS --> MAIN SETTINGS --> INITIALIZE --> OK
Make sure that you do not remove the battery while this process is being carried out by the camera.
Thanks,
Simon
blaireau_photo
Thanks,
Simon
