have a handycAM SONY ccd-trv37 video camera recorder how do i transfer video to my pc is it possible please help thanks
Hi destinyh, welcome to the Sony Forums
Unfortunately the USB drivers for older DV cameras like yours no longer work with newer Windows operating systems.
You need to make a firewire (I-Link) connection bewteen the camera's DV-out port and a firewire port on your PC. If your PC doesn't have one, you can normally fit a firewire card quite cheaply.
Let me know if you need any further help.
Mick
hi thanks for your quick reply need further help if possible how do u do what u stated thanks so much
Hello again
The card you need will depend on the computer you have. Laptops often have PCMCIA slots, which can use a card adaptor like this: http://ecx.images-amazon.com/images/I/31MO7bmMV1L._SL500_AA300_.jpg
A desktop PC is more likely to have a firewire port. If yours doesn't have one, you need to install a firewire card inside. Most computer repair shops will fit them cheaply if you're not sure how to do it youself.
The cable you need looks like this.
Hope that's of some help
Mick
