Bloggie wont charge
profile.country.en_GB.title
cmcary1986
Bloggie wont charge
I've had this bloggie (TS10) for about two years. It had sat for about 6 months and when i went to use it it wouldnt turn on. figured it need a charge. Charged it all day and then it sitll wouldnt turn on.
Im not sure what to do with it, ive even gotten a replacement battery for it and when i plug it in to charge the light blinks orange once (this is after taking the battery out and putting it back in, if i do not remove the battery and unplug it from the usb and then plug it back in, nothing happens) and nothing.
Any ideas what may wrong?
3 REPLIES 3
Mick2011
Hi cmcary, welcome to the Sony Forums :slight_smile:
There was a similar question a while back which was resolved by pressing the start button when the orange light came on:
https://www.sony.co.uk/discussions/message/782740#782740
Should this work for you, a Bloggie reset is achieved by powering off the camera, by pressing and holding the on/off button for 10 seconds, then powering on as normal.
Mick
cmcary1986
Thanks for your reply.
I have tried this several times and is hasn't worked. The orange light isnt even on at this point when its plugged in to charge. When I do get it to blink, its just once when I push the on/off button while its plugged in. Otherwise I cannot get it to do anything.
This is a major bummer. Barely got to use the darn thing.
Mick2011
It does sound like a power supply issue.
It's difficult to say whether the problem is due to an internal fault or (quite possibly) the replacement battery being faulty. I assume it's a genuine branded one?
It may well be worth taking it to a high street camera store and asking for a repair quotation. There's always a chance it's a cheap & simple fix. If you'd rather use the Sony repair service, have a look at this thread: https://www.sony.co.uk/discussions/message/651957#651957
Hope you get something worked out
Mick
