Screen goes off when making call
sarathraj222
Whenever I make calls on my Xperia C4 the screen goes off and can't be restored. To get the display back I should either remove the sim card to restart the phone or connect a charger. What should I do with this..? Please help me....
Christofer
Champion
Hi!
I suggest that you test your phone's proximity sensor in Diagnostics, Settings > About phone > Diagnostics > Test > Ear proximity. When you test it the phone should only vibrate when you place it with the screen facing down and the proximity sensor is covered.
4 REPLIES 4
Christofer
Champion
Hi!
sarathraj222
Thanks for the suggestion.....
The proximity sensor was not working perfectly....
So I tried to remove the tinted glass screen guard on my phone...
Now its working perfectly...
Christofer
Champion
I'm glad to hear that @sarathraj222, thanks for me!
Carll
My problem with my phone Xperia c4 dual also like that when I call the screen black out,how to fix that problem
