Xe90 live colour contrast bug?
haloharry97
I was messing around with my TV settings I saw something strange happening, I was wondering if this normal?
When I change my live colour from off,low or high I can see the box in the middle but if I change it to medium it disappears.
It seems medium setting seems to make my TV brighter. This is all tested in HDR on the PS4 pro, HDR calibration page
https://youtu.be/R8g4b0Mt0FE
Uploaded by haloharry97 on 2019-10-08.
8 REPLIES 8
Pascale_F
Moderator
Hi Harry,
I'll see if I can find this out for you. Maybe someone else in the community can help in the meantime.
Thanks,
Pascale
The_Black_Rose
Specialist
Hi Haloharry97,
I've just had a look into the video and I guess this is related to the PS. Does this happen with any other devices?
Cheers,
The_Black_Rose
haloharry97
Hello, yes
This does happen on other systems,
I have tryed this one the Xbox one X
I think it also happends on TV OS
rooobb
But which is the problem? Livecolour alters the way the source colour are rendered on your tv so it must be switched off in anycase especially if you are using an HDR source that already make use of a wider colour gamut
haloharry97
If it needs to be turned off for HDR then why does it not do that automatically?
rooobb
It is not mandatory. If you like saturated and fake colour it is up to you enabling it. If you look at any serious review they turn off any electronic algorithm.
haloharry97
I injoy the effect on medium, but with this bug, I use high.
rooobb
You have to enjoy it, so, correct or not, let it this way.
It is not known how the different option change the colour mapping but it is same if you try to use a professional colorimeter with this option enabled and try to calibrate the tv: it could not be done. So I assume hardly Sony will consider the effect you shown as a bug.
Same could be said if you try to set a simple setting like the luminance with the light sensor activated: it could not be done because the tv will adjust it independently of which other parameter you are setting..... Hope I clarified my opinion
