Purchased new TV this week and have a question - as the TV has no power button how will I turn the TV on if the Bluetooth remote control stops working.
Hello @Ukchatannie,
but it has. Check the back of the TV.
Location of the On-/Off-Button on the back of the TV - right side if you look at the TV from the front - left if you are looking at the TV from behind.
- Nic
Hello @Ukchatannie,
- Nic
Tain’t the things you don’t know that catch you out - it’s the things you do know that ain’t so...
Thanks found it.
Thanks for this.
