Setting default HDMI input
Jpjbooth
Hello. Does anyone know how I set a HDMI input as the default one, so that each time I turn on the TV it automatically loads that input.. Currently number 3 loads but I want a different one to load now. Thanks
Tags (3)
dutchice
Hi @Jpjbooth,
Welcome to the Sony Online Community! Your XE80 TV is designed to remain on the same HDMI input as when it was on before you switched it off. For this reason there is no option in the settings for assigning a particular HDMI input to act as a default input when switched on.
Cheers,
Dutchice
2 REPLIES 2
dutchice
Hi @Jpjbooth,
Cheers,
Dutchice
Jpjbooth
Thank you for your reply and solving my question :slight_smile:
