Satelite inputs KD48A9
mamtor59
I am expecting delivery of the above set.
I have read the item on setting up satelite tuning but I'm nor sure on the function of the two satelite input sockets.
I have two dishes, 19 & 28 dgrees, I can provide a DiseqC switch. It looks as if the set can control the DiseqC and therefore only one input socket is required. What is the second socket for?
Any help gratefully received.
6 REPLIES 6
IamNic
Hello @mamtor59,
the second socket is there so you can use the twin tuner, meaning you can watch one thing while you record another thing.
- Nic
mamtor59
Thanks for the response.
I did not realise that it was capable to watch and record a second different satellite channel, I presume to a plugged in HDD.
To offer maximum flexibility does the set require 2 DiseqC?  Can it control 2?
Geoff
Joe_Dohn
Specialist
This article is a little dated but it might help, and it is to an external HDD (64 GB or larger).
mamtor59
Thanks for your response,
I will find it easier when I get my hands on the set on Saturday.
I guess it will hep my understanding if I knew why there are two i/p sockets. The article talks of more that 2 i/ps to a  DiseqC switch so that must be an external device.  In a previous post it was stated that you can watch one sat channel and record another, so are there 2 tuners?
Joe_Dohn
Specialist
Yup, it has 2 satellite tuners according to the spec sheet. It's listed under the "Built-in Tuner" section.
mamtor59
Thanks,
Hands on tomorrow.
