KD65A1 Problem - Randomly Turning Itself Off
JdiMambro
I have had my KD65A1 for about 3 months and in the last 2 weeks or so it has started randomly turning itself off. Does not seem to coincide with changing channels or inputs. It can happen in quick succession or only after a couple of days. I have checked the mains connection and reset/updated the software.
Any ideas?
Thanks,
Jules
4 REPLIES 4
Sean_Mc
Moderator
Hi Jules,
We will take a look into this and advise you when we can.
Best wishes,
Ed
Almou_10
Specialist
Hi JdiMambro,
I'd suggest first making sure that the firmware is up to date using this link: https://bit.ly/2xAaKN5. Then, try to reset the TV from Home - Settings - Storage & reset - Factory Settings, and check if this will help resolving the issue.
Hope this helps,
Almou_10
JdiMambro
Thank you very much for responding. I tried the factory reset and then (re-)updated to the latest firmware before I posted. However, pleased to say the problem hasn't occurred for a few days now. I will keep an eye on it and report back. Thanks again for the help! Jules
Almou_10
Specialist
Hi Jules,
Glad to hear this. I would suggest also to clear the cached data on the TV from time to time (like once or twice every week) as this will help maintaining the performance of the TV. You can do that  from Home - Settings - Storage & reset - Internal shared storage - Clear cache.
Cheers,
Almou_10
