- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
KD43XD8305BU starts in HDMI1 as opposed to TV
When started from cold (Power off at mains) my KD43XD8305BU goes directly to HDMI1. I do not have a device connected here. How can I change it to start in Digital (TV) or HDMI3/ARC. If I switch off from the remote it will come back as the source at switch off
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
try an Android TV Reboot, press hold the Power/OFF key on remote...
Manolo
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Does that reset evrything I have set up?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
No, it is only a Reboot not a Reset.
Manolo
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Ok. I'll give it a go this evening
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Mad no difference. I think I will disconnect everything then reconnect one by one and see if it loses the 'memory'
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Mine always starts up on the sky HDMI port which I'm very happy about, is it just a case of the TV starting up on the connection it was switched off in, try switching off in digital and see what happens when you restart.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi
We are expecting a capability to select any other input as default to go to when it is turned on, since Summer 2015.
Nothing is done yet. Sony has forgot this for normal user TV sets. Gives option to proffessional TV sets but not for us.
Do you remember, first setup, if you selected a set top box in HDMI ?
Are you using an IR blaster?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Not sure now what I selected at start. not using IR Blaster. Will attempt to repeat set up from start this evening
