i read that sony tv can connect up to 16tb external drive, i want to buy the new Seagate 8TB external drive portable without power will it work with my Sony KD75Z9F TV through the usb port or i need to buy usb with power source, moreover, doesn't can i connect usb hub to my tv???
Hi @ranma51,
Welcome to the Sony Online Community!
If the 8TB external storage device has an internal Hard Disk it will require its own dedicated power supply. If it has a Solid State Disk then chances are that it can pull the necessary current from the dedicated USB port on your TV marked with a higher current.
The question that makes me very curious is the need for 8TB external storage space.
Cheers,
Dutchice
