Built in you view app aspect ratio 65-xh90 series
frecker77
I have noticed that the centre of the iPlayer image is vertically compressed or elongated. Only with programme images as the iPlayer interface seems OK. This is not evident on any other inputs to the TV nor on the other apps eg Netflix etc. Scaling etc is disabled when in the Youview apps. When using my xBox as the source via HDMI, aspect ratio throughout programmes is fine. Anybody else have this issue and any solutions?
Tags (2)
frecker77
Thank you for your reply!
I would need to look again to be sure but, I don't think that option was available. Screen settings were greyed out - I think.
In any event, the picture is now good. Not sure if it was a device or broadcast anomaly or if my subsequent messing around with the preset motion settings etc did it, but now all good!
2 REPLIES 2
Joe_Dohn
Specialist
Have you tried changing the aspect ratio with the Action Menu/Options button while you have the iPlayer up?
frecker77
