2015 Bravia Android TV Issues
NickCo1979
1) Hot Swap HDMI doesn't work - manifested by no input on HDMI channels 2, 3 and 4 on the KD-49X8305C. Workaround - reset the TV, either by holding down the remote power button for 5 seconds or by switching the TV off at the wall and then back on again. Further details on this thread: https://community.sony.co.uk/t5/televisions/kd-49x8305c-hdmi-2-3-4-inputs-not-working/td-p/1944435
3) Netflix App doesn't work - this seems like the app has been deliberately disabled. So far a support case has only recommended that a factory reset be performed (took two days to get to that cracking piece of advice.....), with no improvement as a result. A temporary (albeit for advanced users only) workaround is provided by MikeLothian on this thread - https://community.sony.co.uk/t5/televisions/netflix-support-for-kd55x8509c-android-tv/td-p/1945360
6,373 REPLIES 6,373
chrgray
@Garymjh wrote:
Yes I think it does 30 50 and 60fps for uhd. And not 10 bit. I presume changing that hdmi setting on the sony from limited to full makes no difference on the sky and bt boxes?
@Risc0n wrote:
People with 4K stutter, has anyone tried changing the enhanced HDMI setting under the inputs section on the TV?
Makes absolutely no difference whether the relevant HDMI input, in my case HDMI3, is in either STANDARD or ENHANCED mode, or if the Display Setting is FULL or LIMITED.  Its why I asked about these settings a few days ago - see http://community.sony.co.uk/t5/televisions/hdmi-signal-format-and-dynamic-range-settings-kd-65x8509c...
chrgray
@frankie1g wrote:
Sky is 10 bit so we need a like for like comparison to rule out the TV. My money is on the TV side as the fault myself.but I hope it is sky because I have more faith in them sorting it out.
Sony have already accepted this it's the TV that needs a firmware update - see http://sony-eur-eu-en-web--eur.custhelp.com/app/answers/detail/a_id/133958
frankie1g
Yes but do you trust them? I habe reverted back to 1080p uhd was so bad
Sent from my Samsung device
frankie1g
So do we expect a pre marshmallow uhd firmware fix or do I phone john lewis and say enough is enough.
rnbetsy
BT box does 10bit
Teknixjack
Yes I have tried both and it still judders
chrgray
@frankie1g, I don't know whether to trust that Sony can fix this by 13th August (when the Sky UHD service begins with Premier League football in UHD).  For my part, I phoned John Lewis and they are liaising with the Sony Escalation Department, so I await that outcome. They had promised to phone me back within 24 hours, but that hasn't happened, suggesting that they can't get a straight answer out of Sony either as to a date that this fault will be fixed.
Without a firm date that is before 13th August, I'll be pressing for a refund or replacement (but not a Sony!!).
hankmarvin107
@frankie1g if you can get a refund get it and run.   get a TV from a company that care
frankie1g
So 10 bit is the issue is it box side or tv side I know sony say they will release a firmware update to solve it.but maybe the boxes need a tweak as well. ANY ONE WITH A 10 BIT non sky or bt input to try.as my faith in sony fault finding is very lacking.
hankmarvin107
Judder problem is also seen on 8-bit, so not a 10bit issue.  This is likely to be a memory or HDMI sync issue caused by  TV
