2015 Bravia Android TV Issues
NickCo1979
1) Hot Swap HDMI doesn't work - manifested by no input on HDMI channels 2, 3 and 4 on the KD-49X8305C. Workaround - reset the TV, either by holding down the remote power button for 5 seconds or by switching the TV off at the wall and then back on again. Further details on this thread: https://community.sony.co.uk/t5/televisions/kd-49x8305c-hdmi-2-3-4-inputs-not-working/td-p/1944435
3) Netflix App doesn't work - this seems like the app has been deliberately disabled. So far a support case has only recommended that a factory reset be performed (took two days to get to that cracking piece of advice.....), with no improvement as a result. A temporary (albeit for advanced users only) workaround is provided by MikeLothian on this thread - https://community.sony.co.uk/t5/televisions/netflix-support-for-kd55x8509c-android-tv/td-p/1945360
6,373 REPLIES 6,373
elraouk
Sky doesn't do 1080p for a start. If it's a Sky HD box then it'll have an hdmi.  Only reason for watching over co-ax would be if the box isn't next to the TV, so using the rf out. If that's the case then a start wont help!
frankie1g
Sky does 1080 i  Sent from my Samsung device
elraouk
Apologies, it does of course do 1080i - my eyes must have invented a phantom 'P' in the original message!
Rest of what I said is still true though, if it is a Sky HD box then it will have an HDMI, so there has to be a reason for using co-ax which would not be solved using SCART.
@HenryHallsDanceBand might help people giving advice if you cleared up exactly what equipment / connections you had (and now have).
royabrown
Enthusiast
@elraouk wrote:
Sky doesn't do 1080p for a start. If it's a Sky HD box then it'll have an hdmi.  Only reason for watching over co-ax would be if the box isn't next to the TV, so using the rf out. If that's the case then a SCART wont help!
Indeed so; a friend of mine who did not want a cable all down the side of the house insisted Sky put his HD box where the existing satellite cable came in to the loft, and then endured the unsatisfactory fist that RF made of his HD channels for about five years.
But at least no-one tried to sell him a YouView box as the solution!
YouView Superuser, but not an employee of YouView, nor retained by them for this purpose. It's purely me speaking
Sad, just sad
elraouk
Was like that in my house when I moved in, but it wasn't HD back then.  Now have the Sky HD box under the stairs and use one of these http://www.hdanywhere.co.uk/multiroom-hd-matrix.html to pipe it via Cat6 cable to four locations.  No noticeable loss in quality, bit or IR lag.   Lucky for me I had the whole house wired with multiple cat6 cables, so this was an option (but not a cheap one).
royabrown
Enthusiast
That link 404s, as the ' to' crept into it :worried:
This link works, though. As you say, not cheap.
ronniebr
Last night I noticed a new "feature" or lack of one.
The "Featured Apps" section had disappeared from my home screen so there was no way to access YouView or iPlayer, All4, etc.  I tried rebooting but that made no difference so I gave up until today when I had more time to do a factory reset which did work.
elraouk
I noticed featured apps wasn't there when I wasn't connected to the internet.
ronniebr
@elraouk That was my first thought as well but the network icon at the bottom of the page seemed to think the connection was ok and I even tried going into the system app update page in settings and the my apps update page in the play store just in case and both said I was up to date.
At least this time after the factory reset I was still able to cast NowTV to the Sony.  I tried to avoid doing a factory reset after the December 10th update because the factory reset I did after the initial YouView update made NowTV think it was a new device and since you are only allowed to add one device a month I ended up not being able to cast to the TV for weeks.
