2015 Bravia Android TV Issues
NickCo1979
1) Hot Swap HDMI doesn't work - manifested by no input on HDMI channels 2, 3 and 4 on the KD-49X8305C. Workaround - reset the TV, either by holding down the remote power button for 5 seconds or by switching the TV off at the wall and then back on again. Further details on this thread: https://community.sony.co.uk/t5/televisions/kd-49x8305c-hdmi-2-3-4-inputs-not-working/td-p/1944435
3) Netflix App doesn't work - this seems like the app has been deliberately disabled. So far a support case has only recommended that a factory reset be performed (took two days to get to that cracking piece of advice.....), with no improvement as a result. A temporary (albeit for advanced users only) workaround is provided by MikeLothian on this thread - https://community.sony.co.uk/t5/televisions/netflix-support-for-kd55x8509c-android-tv/td-p/1945360
6,373 REPLIES 6,373
Twobins
@Cbrpaul01 wrote:
Hello all,
I googled my sony tv and found this forum, please  can you help
I have a Sony Android  KDL50W805CBU, its 3 weeks old , i have the follwoing issues
1.TV turns itself off
2.TV turns back on if turned off
3.Random reboots
4.Picture went into what i desribe as " cartoon view"  almost animated look, had to reboot to clear
5.Freezes on menus
Now i have just noticed i have lost all Satellite channels, im thinking Sony has now removed this with the recent software update, can some please confirn this.
I have until this Friday to return for a full refund, so please advise.
Thank you
Paul
Give yourself time to think and take it back. Sony are very slow in fixing faults and the heavy discounting of these 2015 models indicates all is not as it should be.
elraouk
£499 for the 43X8305C is very cheap, no 5 yr warranty with Amazon, but £140 off the JL price...  Am still within my JL return period...
Cbrpaul01
Thank you for the reply,
Please can you confirm if Sony have removed freesat / satellite functions ?
Paul
Anonymous
Not applicable
Paul
Hi there
Sony TVs are not Freesat, but if you have YouView enabled, the satellite tuner will be disabled.  To use the satellite tuner, you must disable YouView.
http://www.sony.co.uk/support/en/article/109739
Cbrpaul01
thank you for the reply,  and the link , but forgive me , i cant seem to find how to disable youview on that link
Paul
elraouk
Looking on the PC (not app on my phone) and I can see Amazon do do the 5yr warranty. For ?499 it has to be a good deal, even with the quibbles.
Anonymous
Not applicable
Paul
If you would like to disable YouView, press the HOME button and navigate to [Settings] > [Channel setup] > [YouView setup] > [Disable] and choose Yes.
Anonymous
Not applicable
89% claimed - you need to make your mind up :grin:
Edit: make that 93% now
elraouk
Have one in my basket, with 8 mins to run . I do need a second TV, was hoping to get a deal either on the 49" X83C or a 48" Samsung on Friday; but at this price I am seriously tempted to buy it. Not sure I'd go through the hassle of returning the other to JL though if I found a deal on Friday for a bigger set .
Shalendran
@Twobins
I have the same TV KDL50W805CBU but no such issues mentioned. I have not updated to the latest software version though but just one previous to the current one. The few problems i face are no HDD recording, flickering on changing the channels. Sometimes it does not switch on the connected audio equipment eventhough they are all connected by HDMI.
